Electrolux ENN28600
TYPE B257717
Prod no. 925771727-01
Ser no 71900074
Seems to be a very common problem on these no frost fridges but I seem to have checked almost everything and cannot find the problem.Basically the freezer section is operating fine but the fridge section is not cold!.It gets down to a temp of around 10 degrees over night.The only problem I have found was the evaporator drain was clogged with ice,which I melted.The evaporator itself is not iced up and the fins are not damaged.The two thermostats seem to be switching correctly,one is set to 8 degrees and one is set to 20.The heater comes on when it goes into defrost like it should and finally the fan is working fine!.The gasket is not perished and the coils on the back are clean!!.The one thing I find strange is I cannot locate a diffuser so there seems to be no link between the freezer and fridge section.Does anyone know if this model has one?.I have spent a whole day checking things and finally it has got the better of me.Any help or advice from one of the fridge techs would be greatly appreciated.Thanks guys!
