electrolux EOB 6630 X cutting in and out
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries electrolux EOB 6630 X cutting in and out
  • #64707
    slyp98
    hello again , just been to look at this integrated oven , it heats fine thermostat working ok but after 20 mins it cuts out and a little later it starts again , i found a tiny plastic connector inline between the cooling fan and the main selector switch its very black and the coating is burned is this a stat its only 6 to 8 mm by 3mm , thanks guys
    #357849
    Re: electrolux EOB 6630 X cutting in and out
    it is a thermal relay to start cooling fan common fault they go all the time
    part no
    3872079029
    slyp98
    cheers mate sorted
