electrolux eob3400aox 949716231-09
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries electrolux eob3400aox 949716231-09
  • #94647
    adv
    hi guys anyone clued up on these ovens . main fan not going round took top off and small wire was off timer . refitted still same .l. tested fan its fine . timer works element heats up . but just fan not going . wondering if its the timer or . may be the selector switch . .. strange one ?
    #457905
    Re: electrolux eob3400aox 949716231-09
    looks like fan is fed from contact 3 on the selector sw
    adv
    everything works apart the fan . is that contact 3 a live or a neutral? .
    #457907
    this should help
    adv
    am not to good at reading wiring diagrams (
    #457909
    adv
    cheers for diagram . do you think this is more than likely. the switch that is at fault ?
    #457910
    very likely the switch. you can remove it and check contacts
    adv
    cheers
