Electrolux EOB5630W fault
Home Forums Public Support Forums Help And Support Cooker And Oven Forum Electrolux EOB5630W fault
  • #51315
    redjoe100
    Dear UK WG
    I posted the following thread on a well known money saving website, a user kindly advised to replace the following part
    Electrolux Cooker Overheat Protection Thermostat for EOB5630W UK
    I replaced it but it made no difference to the fault. A user also directed me to this site as the problem was too specific. Please can anyone help with this problem as I cant afford to replace my oven or the call out charges for an enginner.
    Many thanks
    redjoe100
    I have an Electrolux EOB5630W fan assisted electric oven, its about 4 years old. Out of the blue the oven seems to cut out when it reaches about 100 degrees, the fan will stop, the light will go out and the heating element switches off.
    There is still power to the oven as the power light is still on. I thought this would be a simple case of replacing the thermostat BUT when this fault occurs its different to the thermostats normal operation…
    Normal – the oven reaches temp and the heating element switches off, the light and fan stay on.
    My fault – before the oven reaches temp – everything switches off (light, fan, element). I then have to wait for hours before it will come back on, usually once I’ve switched off an on the main power switch.
    Any help would be great as a neighbor had the same problem but spent money on a new oven – I haven’t got money (
    Joe
    #307564
    Re: Electrolux EOB5630W fault
    A very common fault, sounds like you may need one of THESE
    What was the part number of the item you fitted. It wasn’t THIS one was it?
    #307565
    redjoe100
    Thanks for replying, here is a link to the part I have already replaced (which has made no difference)
    ALREADY REPLACED
    Shall I try the Oven Cooling Fan Control you have suggested?
    Many thanks again!
    #307566
    The oven cooling fan stat is a well documented, common cause of this fault.
    #307567
    redjoe100
    Ok I’ll try it and post my findings
    Thanks!
    #307568
    redjoe100
    iadom wrote:A very common fault, sounds like you may need one of THESE
    I CAN confirm that it was indeed the “Oven Cooling Fan Control/Stat”, i replaced this with ease and the oven now operates correctly – problem fixed many thanks all!
