Electrolux EOB5630x
  • #84293
    simonb
    eob5630x
    pnc 944 182 598
    H i Guys and everyone called to an apartment in town tiday and the customer being a clever sausage has tryed fitting thr current limiter(the usual cuts out after half hour job) and not fitted one of the white wires in the correct position, its one of the white wires and im sure it goes on the selector switch bank.
    on the selector it has left hand side and right hand side switch bank.
    im sure the white wire belongs on the right hand side very north top looking over from front of machine.
    but a wiring diagram would be fantastic! guys if anyone can direct me in the right direction?
    also guys i did get excitied when i found this from the ukwhitegoods shop
    http://shop.ukwhitegoods.co.uk/media/ca … ontrol.jpg
    but the wire that i need to know the position of is not shown on this photo as its the white wire that disapears under the limiter onto the selector bank, as the other wire connections are shown ok.
    also iv tested the oven, heats on all settings thermostat breaking ok and the cooling fan is kicking and out fine that points towards i have it correct…..possibly :rolls:
    #425318
    Re: Electrolux EOB5630x
    its not a current limiter its a thermal relay
    feed the white wires 240v and the blue wire act like a switch
    sent you a simple diag
    simonb
    Thanks Dave, will go and take a look
