Electrolux EOB5630X oven
  • #33146
    euro
    Got the above fan oven that runs ok for about 15 – 20 mins then the oven cuts of, if you open the door and leave it for a short time it switches back on and runs for a while again, any suggestions what it might be, the thermostat of the klixon?
    Andy
    #237597
    Alanj
    Re: Electrolux EOB5630X oven
    Hi Andy,
    I would say it’s probably the Klixon that’s faulty.
    🙂 LUX 3302081058 THERMOSTAT,KLIXON,90 GRAD from Masterpart £3.69 + vat.
    Alan
    #237598
    euro
    Hi Alan
    Thanks for that, theres actually 2 klixons on it mate, the other 1 is a 210, do you think more likely its the one you have said
    Andy
    #237599
    Alanj
    Hi Andy,
    probably the 210 one. The 90 one looks like it controls the cooling fan on top of oven. Sorry didn’t look properly at TDS disc before.LUX 3302934017 from Masterpart £13.44 + vat. Have you taken the oven out and run it, till it cuts out ❓ You could then test the Klixons to see which one has cut out. ❗
    Alan
    #237600
    Bryan
    I’d say it’s more likely to be the cooling fan control device thingy :).
    Part no. 8996619267611, very common fault and easily replaced.
    Situated behind the control panel, remove a couple of screws from the top and all will become obvious.
    Did one this morning on that very same model.
    HTH
    Bryan
    #237601
    euro
    Thanks for that Allan, had the oven out till it cut of and its the 210 one thats faulty and had to go to another one tonight and found out the thingy that Bryan said about was melted abit. Thanks for your advice Lads
    Andy
    #237602
    Alanj
    Hi Andy,
    Those 8996619267611’s are very common to go on the AEG ovens.Must be a similar breed. Glad we could be of help 😀
    Happy Xmas
    Alan
