model eoc6630x
pnc 944182611
Hi I am going to the above oven on Monday the customer says when she turns it on nothing works but the temp light is on and the light over the slector is flashing 3 times I have looked on the known error codes and cant find anything on this .Does anyone have the codes for this oven or has anyone come across this before.
yellow light is flashing
1X cannot lock
2X cannot unlock
4X temperature sensor defective
5X basic temperature too high
6X electronic too hot
7X wrong connection
the red light is only flashing as a counter, interval 10 sec
Called to this m/c and the customer was right it was 3 flashes and I see from the manual sent from dave that the m/cs with a display give error codes f01 ,f02 etc and the f codes match up with the flashing light codes also on the manual so would I be right in thinking that f03 would be the same as 3 flashes of the light . f03 =eeprom configuation alarm.I have checked everything on the m/c so I do think its the board but am open to suggestions as a new board is expensive.
