electrolux EOG 7330 XN fan on always
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries electrolux EOG 7330 XN fan on always
  • #73914
    slyp98
    hi all , i have this cooker , as soon as the switch is turned on the cooling fan on the r/h side starts up and wont stop , ive changed the stat in the control panel and the changeover stat also there is 3 stats in all , the power is going to the fan through the stats as soon as power is applied anyone please 😕
    #389259
    slyp98
    Re: electrolux EOG 7330 XN fan on always
    anyone ? some tech info even cheers
    #389260
    I’ve just checked and no info, apart from parts illustrations, on Lux site….sorry!
    #389261
    Dales-Electronic
    Is this fan a cooling fan for the digital control? If so it will run from start up and usually for about 20 minutes after switch off.
    #389262
    slyp98
    yeah, it sends the cool air to the top of the cooker and across to the control panel, it comes on immediately as soon as the isolator switch on the wall is turned on is this right ? and it will stop after 20 mins ? i will say it to the customer thanks
    #389263
    slyp98
    went back to this, customer sayes its still on always , so i turned on switch and went off came back 40 mins later and its still on ,anyone know if the pcb controls this fan thanks
    #389264
    slyp98
    anyone have any clue to this , i dont see a cut in stat , which is what controls the electric oven cooling fans , are the gas ovens different ? power coming from the pcb to through 3 stats (all are cut out)and then to the cooling fan , as soon as the switch on the wall is turned on the cooling fan starts and doesnt stop, the cooker shuts off after about an hour and a half of cooking with the manual reset stat tripped out , push down the stat and off it goes again ????
