electrolux eog6330xn sagging hinges
Home Forums Public Support Forums Help And Support Cooker And Oven Forum electrolux eog6330xn sagging hinges
Viewing 1 post (of 1 total)
  • #39950
    eddythefish
    An easy cure for the sagging hinges and the failure of the door to close properly is to remove the top self tapping screws, where the hinge is attached on each side of the oven body (behind oven side plates) , drill slightly larger holes, lever the hinge body back tight by inserting a wide bladed screw driver behind the lug to the side of the screw to be replaced
    (top) , so it holds the door tightly shut and replace the top screw with a small bolt and tighten it up. This worked for me.Any probs ive got photo’s of the pocedeure.
    Eddy.
