Home › Forums › Public Support Forums › Help And Support › Cooker And Oven Forum › Electrolux EOG7330XN Gas. Grill and oven built in
- This topic has 6 replies, 2 voices, and was last updated 6 years, 9 months ago by
John Spencer.
June 18, 2019 at 2:09 pm #96019
John Spencer
ParticipantHi I have had the above cooker for over 7 years now, do not use it too much as I’m always out. However recently it stopped working all together. No power to the led display even.
i seem to remember a similar thing happening a few years ago, but when I asked my friend who would have came to look at it he had no recollection( he fits a lot of cookers and kitchens).I pulled the unit out and checked the mains power and that is fine, also the gas supply is still working as the hob still works fine and sparks up ok. But the main unit has literally turned its self off as if a fuse has blow internally or a thermal cutout has been triggered., Any suggestions on what to try as I’m missing the use of the oven.
Thanks for reading and your time all.
John
June 18, 2019 at 6:05 pm #462077electrofix
Moderatorthe model no is wrong so I cant look it up
can find EOG7330XN or WN
check model and also post PNC number which looks like 944201093 / 00
June 23, 2019 at 7:30 am #462078John Spencer
ParticipantApologies Dave. Here are the correct details.
Model number. EOG7330XN.
PCN number. 944201089.
Thanks for your help.
John
June 23, 2019 at 10:09 am #462079electrofix
Moderatorlooks like a simple timer unit. if the timer has a live and neutral supply chances are the timer has failed.
check for a live and neutral at the timer
dave
June 30, 2019 at 8:41 am #462080John Spencer
ParticipantThanks for your assistance Dave. When you say the timer so you mean the LCD display? If so what voltages should be going into it? Just so I know what to set my multimeter to. So you don’t think the thermal cutout would cut off the display if gone?
Thanks again
John
June 30, 2019 at 9:19 am #462081electrofix
Moderator“So you don’t think the thermal cutout would cut off the display if gone?”
that what we need to find out
the display (clock) is fed 240v ac so you have to check both live and neutral is getting to the display
June 30, 2019 at 9:38 am #462082John Spencer
ParticipantOk thanks. I’ll pull it out and give it a test when I’m back home.
Thank you Dave
