Home › Forums › Public Support Forums › Help And Support › Cooker And Oven Forum › Electrolux EPDOMSS Premier Thermostat replacement
- This topic has 9 replies, 3 voices, and was last updated 12 years, 5 months ago by
medeng1.
November 11, 2013 at 1:21 pm #78040
medeng1
ParticipantI would like some help if possible with a replacement thermostat for a Electrolux EPDOMSS. I have purchased a thermostat part number 506008303006 but it would seem to be a generic part and has less connections than the original. I was hoping someone would be able to provide wiring instructions for this new thermostat.
Thanks for your help
Andy
November 11, 2013 at 1:43 pm #404268don
ModeratorRe: Electrolux EPDOMSS Premier Thermostat replacement
There are three different versions of that oven. The only way of finding out if you have the correct stat is to give us the serial number of the appliance.
Some parts for that model are obsolete so it’s a case of keeping everything crossed.
Sadly rule 8 in the forum rules does not allow us to give wiring guides.
HTH 🙂Don
November 12, 2013 at 3:07 pm #404269medeng2
ParticipantRe: Electrolux EPDOMSS Premier Thermostat replacement
Hi info as requested new thermostat ET51001/F5 part no 506008303006, my oven is EPDOMSS Part No 944171135
November 12, 2013 at 3:25 pm #404270don
The 944 number you gave is the product no. or sometimes known as the PNC.
The serial number we need starts anything up to 117……
Or it could be 118….. to 212…..
Or even 213….. and further on.
Don 🙂November 12, 2013 at 3:45 pm #404271medeng2
Hi SN is 05000029
November 12, 2013 at 4:19 pm #404272don
Right then there are two thermostats on that appliance one for each oven. If you look at the control panel, counting from the right is it the first or third one?
Don
November 12, 2013 at 5:04 pm #404273medeng2
It’s the third from the right, the main oven thermostat. Thanks again.
November 12, 2013 at 5:24 pm #404274don
Give me 24 hours and I’ll have another go 😀 unless anyone else steps in.
DonNovember 13, 2013 at 1:09 pm #404275don
Electrolux group spares say ” item obsolete and no substitute available” however I chanced across this thread which does list stat part number 3111622019 which is the one for your serial number. Whether you want to go down this route or not is up to you.
HTH 🙂Don
November 13, 2013 at 2:48 pm #404276medeng2
ok great thanks. That gives me something to go on. Will report back once I try.
