Electrolux EPSOPMSS
  • #22875
    johnny123
    Have a problem with our Electrolux EPSOPMSS oven,
    prod – 944250330
    serial no – 24900713
    Whilst baking it suddenly went pop, and the circuit breaker for the cooker circuit tripped. On resetting nothing on the oven works ie no LEDs, lights, heat or fan etc. There is power to the cooker, as the separate hob works fine.
    Have disconnected and checked the element which seems fine (ie not open circuit).
    Whats the most likely thing I should check next? Maybe its a thermostat or circuit board?
    Any help would be appreciated.
    #196373
    Re: Electrolux EPSOPMSS
    johnny123 wrote:There is power to the cooker, as the separate hob works fine.
    I would be looking at the terminal block in the oven and the safety cut-out for a start. Failing that, the big power board may well have fried – expensive, over £90 last time I checked.
    Stay safe, power off.
    johnny123
    Thanks Penguin!
    The terminal block looks fine, with no sign of burning.
    Where do I find the safetly cut-out? Is this on the power board?
    #196375
    johnny123
    Hi, Have looked at the power board and can now see that on the back the circuit is burnt through in a number of places.
    Where do I get a new board?
    The numbers on the board are:
    SP0B10 SOEC OL 34th 20th April 1999
    Elux GPDhot TC
    Any ponters woud be appreciated.
    Thanks again
    #196376
    Power board is p/no 3722161-63/9 – email that number through to spares@ukwhitegoods.co.uk and they’ll get you an updated price and order one for you.
    BUT – why did it blow? Most machine made digital control boards seem to suffer from poor solder joints and dry joints; exploded boards (lots of tracks off) is usually a short circuit somewhere.
    HTH,
    johnny123
    Thanks again Penguin!
    Yes have some tracks off and some componnts burnt through.
    Sounds like its not worth trying to fix this, as cant see obvious short cct elsewhere and part costs are already too high.
    Thanks for the great advice. Have learnt a lot.
    Reagards
    #196378
    den06
    Hello All,
    I want to know where i can order such of board for my cooker.
    Eletrolux : SP0B10 0L 34th 20 April 1999
    Thanks.
    Denis
    #196379
    Penguin45 wrote:spares@ukwhitegoods.co.uk
    Be absolutely sure that this is what you need………
    paliso
    priere me faire parvenir par e-mail le shema technique de la carte electronique sous reference SPOB10 OL 34th 20April 1999 car ma cuisiniere de marque ELECTROLUX est en panne et neccessite le shema technique pour sa reparation
    mon E-mail est le suivant : paliso@yahoo.fr
    en vous remerciant vivement.
    a bientot
    merci
    #196381
    gandh1
    paliso wrote:priere me faire parvenir par e-mail le shema technique de la carte electronique sous reference SPOB10 OL 34th 20April 1999 car ma cuisiniere de marque ELECTROLUX est en panne et neccessite le shema technique pour sa reparation
    a bientot
    merci
    en anglais parle vous sil vous plait
    #196382
    paliso
    please send me by e-mail technical shema electronique map under reference SPOB10 OL 34th 20April 1999 because my brand ELECTROLUX cuisiniere is down and the shema neccessite technique to repair
    my e-mail is: paliso@yahoo.fr
    thank you very much.
    thank you
