Home › Forums › Public Support Forums › Help And Support › Fridge And Freezer Forum › electrolux er2944b fridgefreezer fridge part warm
- This topic has 9 replies, 3 voices, and was last updated 20 years, 8 months ago by
admin.
August 6, 2005 at 7:39 pm #11143
Keymasterhi, my electrolux er2944b fridgefreezer has a fault – the fridge part does get very cold , could it be the thermostat , steve
August 6, 2005 at 8:57 pm #144100admin
KeymasterRe: electrolux er2944b fridgefreezer fridge part warm
steve23579 wrote:hi, my electrolux er2944b fridgefreezer has a fault – the fridge part does get very cold , could it be the thermostat , steve
sorry guys, i meant to say ” does not get very cold “.
August 6, 2005 at 9:27 pm #144101Dave_Conway
ParticipantRe: electrolux er2944b fridgefreezer fridge part warm
It could be a number of things Steve to be honest.
I can’t access the Electrolux tech website tonight as it appears to be undergoing some maintenance……
Is the unit frost free ? (I think it is) If so, try a total defrost as the freezer section may be blocked with ice restricting the cold air from reaching the fridge section, check for obvious air inlets and outlets (vents) in the fridge please before doing this as some frost free units have a conventional fridge evaporator 😉
August 7, 2005 at 7:40 am #144102admin
hi, thanks for the reply, my missus says it is not “frost free” the hand book seems to confirm this , but she will try to defrost it to day , ill post back and let you know.
August 7, 2005 at 9:29 pm #144103admin
hi,defrosting has not worked,so i dont know ,
#1 the fridge light is on
#2 the compessor/motor is hot
#3 the fridge on top does not cool at all
#4 the ” radiator ” inside the fridge on the back wall is normally icey – it is room temp.
#5 the freezer below is working fine
#6 the fridgefreezer seems to be making all the normal ” sounds “
any help would be much appreciated, steveAugust 8, 2005 at 7:31 am #144104Dave_Conway
OK, I have the info now.
It isn’t frost free as you say and it may well be the fridge thermostat as this unit has a solenoid device that diverts/sends gas to the fridge when required.
Part number is 2112680000 at £27.33 inc VAT and delivery.
If you’re unsure though and need a definite diagnosis, check Repairs@ for an engineer, or if you decide to check yourself, power off first please :plug:
I can order the thermostat for you, an email to spares@ukwhitegoods.co.uk please.
August 8, 2005 at 10:38 pm #144105admin
hi, thanks very much for the reply, i can confirm it is the thermostat, i have bridged two wires on the faulty original and the fridge has kicked in o.k. ! , i had already ordered a universal thermostat this morning b4 your post, if it does not do the trick i will order the one on your link. again , thanks very much for all your help, steve.
August 9, 2005 at 6:19 am #144106farmboy
Steve, you will definatley need the genuine thermostat on this one, a universal stat wont work.
August 9, 2005 at 9:05 pm #144107admin
hi, well guys, the universal stat arrived this morning and i can confirm it is a load of sh!te. it does not have the single pole changeover switch fitted to the original but in stead an arrangement of two series switches ! the original is on its way 😳 , thanks to all.
August 10, 2005 at 9:14 pm #144108Dave_Conway
steve23579 wrote:hi, well guys, the universal stat arrived this morning and i can confirm it is a load of sh!te.
It’s perfectly suitable for the purpose it was intended, hence the reason I didn’t suggest it as it is not suitable for your model 😉
Please feel free to return it for a refund as long as no attempt has been made to fit it 🙂
