Electrolux ER7926/1B Prod No. 925888655-01
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Electrolux ER7926/1B Prod No. 925888655-01
  • #24279
    Alanj
    Hi Guys,
    one for the refridgeration experts. Freezer working but no cooling in fridge. I suspect the evaporator in the freezer section is solid with ice.What is the probable cause of this? Defrost heater not working?defrost timer? How do I test these components? I don’t do a lot of frost free appliances and would be grateful of any help.
    Alan
    #201429
    Fairdeal
    Re: Electrolux ER7926/1B Prod No. 925888655-01
    Hi Alan,
    Most of the times it just happens by itself.sometimes they leave the door open for longer period i.e. while putting food in the freezer etc so it builds up with the ice.
    I think the best thing is always ask the customer to defrost it manually(by switching it off for 24hrs)and then swith it back on.If the problem presists then investigate further.
    I am not sure about this model but most Zanussi/Electroulx F/F come with a cutout sensor that needs replacing in case it goes.It has a sensor that is attached to the coil and then one of its wire has a small builtin fuse.
    Testing the heater is like any heater just check for the resistance.
    And lastly if there is a mechanical defrost timer then just turn it manually and see if the heater comes on,if it does not then the defrost time is gone.
    Hope it all makes sense.
    Regards
    Omar
    #201430
    Alanj
    Hi fairdeal,
    I have told customer to defrost the freezer and let me know if she has any more problems with it. Just thought I’d check with you guys for future.
    Alan
    #201431
    Simon46
    Been to one yesterday similar. turn defrost heater ice melts ok. Son had same fridge freezer and serviceforce removed Whoopee cushion bung on defrost drain under guarantee.
    Timer sticking do you think??
    Regards
    S.
