Electrolux ERN34800 – Evap NTC
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Electrolux ERN34800 – Evap NTC
  • #102344
    Hollytree_Technical
    Prod: 923800734
    Serial: 81400008
    Hi All
    Does anyone know the exact location of the Evaporater NTC in this unit please and is it changable?
    I have found the service bulletin about changing the air sensor on the unit but it doesn’t tell me where the evap sensor is, I have had to disconnect the evap sensor from the board as it was giving a reading of approximatley 960 Ohms (above 40C accoring to the conversion chart) but the unit wasn’t throwing an error and was instead freezing everything.
    Thank you
    Jem
    #488425
    looks like a board change
    from the bulletin
    “Even if the faulty temperature sensor of the evaporator is still connected to the connector, the new circuit board uses only the air temperature sensor of the refrigerator”.
    will send you what i have found. may be the same tech
    Hollytree_Technical
    Hi Dave
    Looks like you managed to find a more comprehensive bulletin than I did as the one that I was looking at only showed the Kit B info.
    Thank you
    Jem
