Home › Forums › Public Support Forums › Help And Support › Dishwasher Help Forum › Electrolux ESI 600 Blue Tubes – Sticky timer, no heat
- This topic has 9 replies, 3 voices, and was last updated 19 years, 10 months ago by
bornlivelife.
June 25, 2006 at 9:51 am #18699
bornlivelife
ParticipantWould be so grateful if someone can help with this.
Dishwasher has been great up til now – think its about 4 years old
But now, on any program the unit fills ok washes a bit and then stops. Manual advance gets it going another 3 minutes then it stops again. It does theis 5 times in a program and I have to miss lots of parts of the cycle out so the plates arent clean. There is no heating either. It does drain fine so appears pump and outlet are fine.
Followed advice on this forum but havent found the problem, ie:
Cleaned blue tubes, cleaned “u” tube, cleaned filters, cleaned spray arms (it was all pretty clean anyway), checked heater element circuit and its fine, checked connections on timer etc they seem ok.
Do you think it could be thermostat?
Best wishes, Peter
June 25, 2006 at 11:10 am #179993Penguin45
ParticipantRe: Electrolux ESI 600 Blue Tubes – Sticky timer, no heat
Thermostat, heater or broken wires in the door are likely culprits. First two you’ll need a multi meter to investigate correctly.
Power off if removing any panel, or click the link below for a UKW engineer in your area.
Penguin45.June 25, 2006 at 11:27 am #179994bornlivelife
Thank you – you’re very kind – will have a look then see what parts I need to buy
June 25, 2006 at 6:37 pm #179995bornlivelife
Hello
Ive checked something that could be a thermostat, its round and about 50mm diameter plastic made by KEMA EUR and has numbers ( 05/99 761143 , 0611 60/27 on it) It has a breather tube coming out of it and 3 connections red (2 wires) black (1 wire) grey (1 wire). Circuit seems a bit weird, it does the following:
RED-BLACK : NO CIRCUIT
RED-GREY : NO CIRCUIT
GREY-BLACK : CIRCUITDoes that mean its working or broken, and is this the thermostat please?
June 25, 2006 at 6:53 pm #179996Dave_Conway
That’s the pressure switch 😉
May I suggest an engineer at this stage ?
Check the repairs@ link below for a local Independent 🙂
June 25, 2006 at 6:59 pm #179997bornlivelife
Hmm this is quite tricky ! I already contacted someone through that link so hopefully someone will get to me on Monday – thermostat must be in the electric panel then near the on/off switch…
June 25, 2006 at 7:41 pm #179998bornlivelife
Found some more things:
1. Door open/ close circuit : works fine
2. At bottom of a water chamber – White thing dia 20 with 2 wires – CIRCUIT OK
3. Next to heater a black thing with lots of wires: orange (2 wires) in, orange (1 wire) out; purple (1 wire) in, purple (1 wire) out
All circuits give a reading which sounds odd
ORANGE a/ ORANGE b : CIRCUIT OK
ORANGE a /PURPLE b : CIRCUIT OK
ORANGE a/ pURPLE a : CIRCUIT OK
PURPLE a/ PURPLE b : CIRUIT OKIs this the thermostat, and should it be reading that?
June 25, 2006 at 8:08 pm #179999bornlivelife
Right item 3 is the thermostat Im sure about it! But from circuit check I think its working
So I think I need a new timer because everything I check seems to be ok. What do you think?
June 25, 2006 at 8:33 pm #180000Penguin45
Do not replace the timer, you may well be wasting £75. There are too many variables here – have you got a reading through the heater for instance? One of the symptoms of the blue tube problem is no heat – the water is shut off by the safety system at the inlet valve, rather than the pressure switch. If the pressure system does not actuate, there is no heat.
Penguin45.June 25, 2006 at 8:43 pm #180001bornlivelife
Yes the heater has a reading – circuit is ok – you think its the safety system at the inlet valve then?
