electrolux esi 602 wont fill with water
Home Forums Public Support Forums Help And Support Dishwasher Help Forum electrolux esi 602 wont fill with water
  • #14860
    lizard
    i have an intregrated es602 that refuses to fill with water, i have checked the mains hose its fine. i have located the valve under the machine and removed it it seems to be blocked or not functioning, has any body had a similar problem? where can i get a valve for this machine?
    #161101
    Dave_Conway
    Re: electrolux esi 602 wont fill with water
    It may be a blockage causing this rather than the valve, there are various issues with filling problems on these Zanussi made dishwashers.
    If you use the forum search for “IWMS” (without the quotes) you’ll find loads of info on this fault 🙂
    #161102
    lizard
    thanks i will give it it a try.
