Hey Guys ,
This machine is 2 years old , Normally you would select a programme and hit the start button . But when you select any programme from the off position it begins to fill , it will keep filling and bring in the wash pump then it will bring in the emptying pump after about 4 to5 minuites . When its empty , it will flash the “start LED” on the facia. There are 5 verticle LEDs showing the progress of the wash , the middle LED is flashing also but not as often as the start one
I checked the pipes to both pressure switchs all clear no blockage . This machine has been doing the fast wash 45deg so I went looking for gunge . It seems to be as clean as a whistle .
I am glad to get any help thanks !
MK
