We had our door latch break, so bought another from epsares… all looking good up to this point. I managed to wire it up wrong which tripped the mains (blew basically…) and now that the door latch is correctly wired up (i think) the machine won’t switch on at all!!
Ive tried changing the fuse in the 3 pin plug but apart from that, Im scratching my head…. anyone got any ideas???
Thanks. I didn’t think there would be another fuse hidden away somewhere…. I think at £139 for a circuit board I’ll be better off purchasing a new machine…
Thanks again…
Pray tell how did you wire up a door switch incorrectly, there are only 2 wires on it, either way around you put them it will work.
It shouldn’t trip mains unless it touched against casing for instance.
