Home › Forums › Public Support Forums › Help And Support › Dishwasher Help Forum › Electrolux ESL5201LO Intermittent drying issue
- This topic has 8 replies, 2 voices, and was last updated 2 years, 11 months ago by
beezas.
May 9, 2023 at 5:50 pm #101945
beezas
ParticipantMy 5ish year old Electrolux ESL5201LO has developed an intermittent issue. The drying cycle doesn’t seem to work properly but this doesn’t happen all the time. I’ve opened the door during the wash and the water was warm. This comes after another intermittent issue which hasn’t re-occurred for a good while, it seemed to be getting ‘stuck’ on the wash cycle for hours on end. Like I say though, that doesn’t seem to be happening any more but the drying issue crops up fairly often, it’s pretty much cold end in there when you open the door at the end of the cycle as opposed to the clouds of steam when it’s working properly.
Any ideas please?May 9, 2023 at 8:31 pm #486807beezas
ParticipantThanks Dave, There’s current to it sometimes – that’s the problem. It’s an intermittent issue. I don’t know how I can “advance” the cycle to the dry stage when it’s playing up and see if there’s current then.
May 9, 2023 at 9:07 pm #486808electrofix
Moderatorforget what i said, I have deleted it. somehow i had washing machine in my head
ok you said its warm sometimes, is it plumbed into hot water which could give the impression its heating
DaveMay 10, 2023 at 6:06 am #486809beezas
Participant…nope just a cold water feed.
May 10, 2023 at 8:52 am #486810electrofix
Moderatorintermittant faults are hard to find and thats your biggest problem
I think if it was me i would start by replacing the motor tacho coil. this is not a part electrolux supply but the coil off a beko washing machine fits ok. this coil detects to see if the motor is turning and wont turn on the heater unless it does. its a common no heat failure if the element is ok
do a google search for 372205505
May 10, 2023 at 9:16 am #486811beezas
ParticipantAre you thinking washing machine again?
May 10, 2023 at 4:10 pm #486812electrofix
Moderatorno dishwasher motors have a tacho
look here
May 11, 2023 at 6:06 am #486813beezas
Participantoh right thanks – what role does the circulation pump play when drying please?
May 11, 2023 at 8:23 am #486814electrofix
Moderatorwell the water has to heat up so things will dry so motor has to be running during the heating phase. Once its heated the pump does not play any part in the drying process as its down to the rinse aid and heat
