Electrolux ESL6114 d/w
  • #20444
    effzedarr
    This one has puzzled me a bit, every 10 months or so customer complains of no water going in to m/c. The valve hums like the water has been tuned off. But it ain’t, so remove valve ,blow down pressure pipes & suck any water out off the overflow valve that piggybacks the inlet valve ,reassy & away it goes for a few more months,
    It must be an overflow problem but most pipes go to the fill reservior on the lefthand side of the m/c, but that seems clean & the pipes going to the sump are all clean! Anybody else had this prob! It does seem strange that it runs ok for months. Cheers Chris…
    #187092
    Re: Electrolux ESL6114 d/w
    IWMS problem by the sounds of it.
    #187093
    cab
    not the iwms modification to the fill valve and pressure switch there is a mod
    cab
    #187094
    Explain?
    effzedarr
    Yeah wots this IWMS m’larky?
    Chris….
    #187096
    cab
    iwms Inegrated Water Management System- the side tank!
    cab
    #187097
    cab wrote:iwms Inegrated Water Management System- the side tank
    We knew that bit – curious about mods. 😀
    cab
    penguin, did you get the email I sentwith the service bullitin on?
    #187099
    Aha! That was you – TVM, v interesting 😀
    cab
    ok
