Electrolux ESL6115 (911939201/01)
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Electrolux ESL6115 (911939201/01)
  • #80325
    rocker
    Having problems with this dishwasher, the problem is low heat, replaced the heater same fault, sent pcb to emw for repair, same fault. I tested on 65 deg fast wash and 70degs heated pre wash. on both these cycles it appears to fill wash empty, refill wash empty, so I think the problem may be the programs are out of sink, is this a possibilty not sure if to replace pcb without knowing. cheers John
    #412449
    Criscold
    Re: Electrolux ESL6115 (911939201/01)
    Have you gone into diagnostics as these don’t show a fault code on heating faults, the heating is cancelled and the machine will complete the cycle.
    Let me know if you req procedure/manual
    Colin
    #412450
    rocker
    Colin, I have sent you a pm. john
