Hello, I have an Electrolux 6115 dishwasher that has worked fine for 10 years until yesterday. When I switch on the door power button ready to set the programme it starts what sounds like the drain pump working – it gurgles as if it is trying to suck but there is no liquid to suck. Obviously it shouldn’t be doing anything at this stage as I haven’t selected a programme and closed the door.
If I hold down the Cancel button as if to cancel a programme the gurgling stops after a few seconds. I can then select a programme but when I close the door to start it nothing happens. I’ve noticed that the End Programme LED is flashing 8 times if that is significant. Any help would be much appreciated as I like to fix rather than replace (and I’ve just spend £40 on a new lower spray arm and rollers for the bottom drawer!).
Thanks in advance
Ben
