Re: Electrolux ESL6211LO – Error
Scs17,
Can you see the images I have attached to my post above? There are two showing both the pressure switch in situ as well as removed.
This part is not difficult to remove, if you are struggling then you may be looking at the wrong part. To remove it note that:
+ On one end is a push fit fluidic connector that the inside of the dishwasher feeds into. Disconnect this first to make the electrical connector more visible
+ On the other end is an electrical connector. This connector has a small tab that needs to be lifted/deflected while you pull the electrical connector to allow it to be removed.
+ Remove the switch and inspect/rinse and reinstall. Hopefully this will work.
Let me know if this works for you.
