Home › Forums › Trade Technical & Spare Parts Forums › Trade Technical Enquiries › electrolux ESL6225 D/W
- This topic has 12 replies, 5 voices, and was last updated 18 years, 7 months ago by
rocker.
September 12, 2007 at 1:27 pm #30493
rocker
ParticipantBuilt in dishwasher.
Have no negitive to heater..traced cable back to pressure switch..
pressure s/w activates when I tested…I have continuity between pressure s/w to top facia on/off switch. cant test for power as I cant get meter probs into connections. am I missing anything and can anyone offer any advice, the next thing is to change the pcb…risky!!
Cheers John.September 12, 2007 at 4:06 pm #227378senseib
ParticipantRe: electrolux ESL6225 D/W
Is the heater element chamber ok? – They go open circuit, common fault! (Part number: 50280071007)
Brian.
September 12, 2007 at 6:12 pm #227379rocker
Brian,
Tested heater circuit ok..have no neg to heater !!September 12, 2007 at 6:16 pm #227380senseib
Most likely suspect PCB then… 😈
Brian.
September 12, 2007 at 6:21 pm #227381Penguin45
The “dry-joint-on-pcb” debate will start shortly………..
September 12, 2007 at 6:34 pm #227382rocker
Chris, visual check on pcb, no sign of dry joints ??
September 12, 2007 at 7:44 pm #227383Penguin45
Bumf in your in-box, Rocker.
September 12, 2007 at 8:04 pm #227384rocker
Chris, cheers mate received info.
JohnSeptember 12, 2007 at 9:01 pm #227385admin
KeymasterRe: electrolux ESL6225 D/W
Sometimes I use one trick: measure where on interesting point (like pressure switch or heater) is coming L (live). After that I switch plug into main plug and see if I have L (live) came on other….if not I go thru this channel to see where is disconnected (interrupted). 😉
September 12, 2007 at 10:19 pm #227386rocker
baron wrote:Sometimes I use one trick: measure where on interesting point (like pressure switch or heater) is coming L (live). After that I switch plug into main plug and see if I have L (live) came on other….if not I go thru this channel to see where is disconnected (interrupted). 😉
ok, thanks for the advice – I’ve done these tests.
John.
September 13, 2007 at 8:20 am #227387admin
KeymasterThen you have found which wires from heater are comming to power PCB ( with water inside verify that electronics see heater). If it is OK look on PCB which relay is corresponding to heater and you will find him damaged or his tracks.
September 13, 2007 at 1:03 pm #227388rocker
Baron, thanks for that will check this out.
JohnSeptember 13, 2007 at 2:01 pm #227389Alanj
Hi Rocker,
are you getting L + N coming into machine? Have had instance where plug or socket were faulty.Try different socket?
Alanj
