electrolux ESL63010 (D/W)
  • #57630
    rocker
    Have low voltage to water valve (around 150v) I am thinking it may be the timer pcb, can anyone please confirm or advise.
    Thanks John
    #331782
    Re: electrolux ESL63010 (D/W)
    at 150v to valve although this seems low i would still expect valve to open but as you say if this is the case then the pcb should be giving 240
    sound like the triac that feeds the valve is faulty and only giving half wave supply
    are you getting any fault codes ?
    rocker
    Dave, no faults codes viewer on this appliance !! sounds like a new pcb then !!
    John
    #331784
    sound like
    but if you want the service info let me have PNC number
    and an email address
    rocker
    Dave, would appreciate you sending me the service Info.
    many thanks John.
    email. ableappliances@gmail.com
    #331786
    sent but its a big email because you did not state pnc
    so if you dont get it will send in 2 halves
    rocker
    cheers Dave.
