Electrolux esl63010 doesn’t always start a wash
Home Forums Public Support Forums Help And Support Dishwasher Help Forum Electrolux esl63010 doesn’t always start a wash
  • #99060
    Alex Lee
    We have an integrated Electrolux esl63010 that’s intermittently not starting. It sounds like the pump tries to start and then stops.
    When this happens I usually reset the wash options and try again. Generally, 1-4 reattempts work and the wash starts.
    I’m not noticing any issues with it holding water or not washing correctly
    I’m unsure what’s causing this and could do with some advice, please.
    I’ve tried:
    • Different wash cycles with no difference
    • Check the salt levels
    • Took the machine out to check for blockages in the pipes (none). Oddly after that, it worked reliably for about a week before the intermittent non-start came back
    #474886
    You need the product code for that one (explained here) as there are multiple versions but, given it worked after moving it, a kinked hose or blocked outlet perhaps? Or a dodgy drain pump as it will drain to clear the sump before starting.
