electrolux esl7220ro 911435301 09 no heat
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries electrolux esl7220ro 911435301 09 no heat
  • #101194
    mikehha
    hi all I know what your thinking its a tacho on the motor thats stopping it heat, well not this time and its not the heater ? So has any one had a go at repairing the module on the back of this dishwasher. I take it to be a relay fault as I`m only getting 116v at the heater. any info or thoughts much appreciated.
    #483753
    hebegebe
    I had this fault a while back, and went to the board before I knew the the tacho was the most likely cause. I changed one of the relays in an attempt to sort it before Dave put me right with the tacho advice. There were two relays controlling the heater, but switching L & N as I remember. If one were to fail it wouldn’t give 116v at the heater, but under no load conditions the 116v may just be a red herring being half of 230v. (Was that reading taken across the heater terminals? If so it implies some current flowing.) Further than that I can’t really help. The rear module was a devil to take out – wiring holding it tight – but beyond that it’s easy enough to access relays which were 12v as I recall.
    Graham
    #483754
    double check the tacho resistance with it unplugged and temp sensor before you jump on the board
    mikehha
    thanks all and yes dave tacho is 225 but will go back and check thermistor if ok will remove board.and have a play what have I got to loose thanks again mike
