electrofix wrote:Re: Electrolux ESOMSS cooling fan will not stop
seems to be controlled by a stat mounted by the grill terminal
sent you a pm that may help
page 31 item 2
Can you send me same info as I have same issue with AEG 94417152902? Cooling fan won’t stop. Thermal limiter with green dot on top of grill appears to be in order (closed circuit). If this is thermal cut out, it should cut off at 110deg? I,m trying out the rubber thermal limiter to see if this cures.
