Home › Forums › Public Support Forums › Help And Support › Washing Machine Help Forum › electrolux EW 1200 1 drum not spinning
- This topic has 9 replies, 6 voices, and was last updated 18 years, 8 months ago by
mrfitzy2u.
July 15, 2007 at 3:28 pm #29019
mrfitzy2u
ParticipantHello,
I have an electrolux EW 1200 1 which the drum is not spinning. (SN: 44700058)
On any wash cycle it starts to fill with water, you can hear a motor trying to spin drum, but the drum does not move. The drum can be manually spun, so is not stuck.
It is 2.5 years old, out of warranty, and would be grateful if anyone could offer advices as to what the problem might be so I can can decide if a repair is economic or whether to replace.
Justin
July 15, 2007 at 3:34 pm #221155Penguin45
ParticipantRe: electrolux EW 1200 1 drum not spinning
Carbon brushes:
http://www.ukwhitegoods.co.uk/modules.p … ge&pid=156
Drive belt:
http://www.ukwhitegoods.co.uk/modules.p … ge&pid=216Can possibly be electronics, but not a common problem on these.
Power off before going in………
July 17, 2007 at 4:43 pm #221156dna
I disagree if you can here the motor but the drum doesn’t turn then its most likey the belt dont you think penquin.
July 17, 2007 at 6:01 pm #221157richardable
prove motor action by taking the back off.. select spin program .at the same time you can see if the belt is off!
richardJuly 17, 2007 at 9:25 pm #221158iadom
ModeratorRe: electrolux EW 1200 1 drum not spinning
dna wrote:I disagree if you can here the motor but the drum doesn’t turn then its most likey the belt dont you think penquin.
You disagree, however it seems you did not read the full post from P45, as clear as day on the third line, DRIVE BELT, :rolls:
Back off is not that simple on these richardable, the rear half of the cabinet has to be removed.
Justin, if you open the door and spin the drum by hand does it seem to spin as it normally does, or does it seem to be very free and keep on spinnig longer than normal, it it does the your belt will have come adrift or failed, if the belt is adrift but still in one piece then it still needs replacing.
July 17, 2007 at 10:53 pm #221159richardable
sorry about the back off, as above spin the drum by hand. then UNPLUG and take the top off..see if belt is on pulley..if not the back will have to come off..if its the same as a zanussi you will need an 8mm socket spanner, to get all the securing bolts off..4 either side at the top, 2 each side (bottom of rear side panel concealed with plasic plugs) and 2 at the back at the 2 bottom corners
richardOctober 20, 2007 at 10:21 am #221160teobg70
Hello everybody,
I’m new to this forum.
I have now exactly the same problem (at least same symptoms) as Justin back in July. My model is EW1000i.
If moved by hand the drum spins freely, no resistance at all. Before that there was a lot of noise coming from the backside, now the noise is gone and the drum does not move anymore but the engine is clearly trying to spin.How do i know if the belt is gone?
Many thanks,
teoOctober 20, 2007 at 11:20 am #221161richardable
as above..unplug..take top off and you can see if the belt is off the drum pulley..however if it has been noisy and now the drum can’t be turned you may have more severe damage, drum bearings at worst, belt is off and is caught between the pulley and the drum which jams drum movement…top off is the the quick way to find out..UN PLUG FIRST.
richardOctober 22, 2007 at 9:52 am #221162teobg70
Many thanks.
I couldn’t see the belt from the top but i found it on the bottom of the machine…
Do i need a special tool to put the new belt?
The manchine is only 2 and half years old and i read on this forum that lifetime of belts nowadays is much longer, therefore i suspect there is something else wrong (bearings. etc.). By the way the drum is moving freely by hand, i do not feel any resistance, maybe the bearings are ok…
The only thing i could notice is avery dirty filter. Can this be a cause for the broken belt or surely has nothing to do with it?
Thanks,
TeoOctober 22, 2007 at 12:38 pm #221163richardable
see post of july 17th for removal of back half of cabinet,, be carefull if your inlet hoses are short, don’t stretch them!!! UNPLUG…before you start.
no special tool needed to re fit belt,
richard -
