Home › Forums › Trade Technical & Spare Parts Forums › Trade Technical Enquiries › Electrolux EW12001 (914674010/01)
- This topic has 8 replies, 3 voices, and was last updated 13 years, 9 months ago by
rocker.
June 30, 2012 at 3:55 pm #70225
rocker
Participantbeen to see this machine, when set on K cycle 50degs wash,the cycle goes into a fast spin only…any advice as to possible cause please, have tested a couple of other programes no faults.
Thanks JohnJune 30, 2012 at 5:21 pm #377458Martin
ParticipantElectrolux EW12001 (914674010/01)
Tacho problem, pure and simple. 😉
July 1, 2012 at 10:45 am #377459rocker
ParticipantRe: Electrolux EW12001 (914674010/01)
Thanks Matin, but why dosen’t this effect other cycles.!!!
JohnJuly 1, 2012 at 4:10 pm #377460Martin
Dunno, are you sure you are not confusing fast spin with the ‘active agitation’ that some cycles are programmed to do anyway? If it did go into fast spin as you describe no doubt the water would pee out of every orifice and deposit on the floor as a result. So does your customer have to wade in there with a mop and bucket whenever she selects that K cycle?
Joking aside, I think we may be looking at a dodgy tacho here all the while TBH..works OK one minute, then when your back’s turned off it goes!
July 1, 2012 at 4:38 pm #377461rocker
Hi Martin, weird no water is taken in at all on this programe, just starts a spin cycle and conts till end !!
put it on all other wash programes and water is taken in on all!!
and work fine.
JohnJuly 1, 2012 at 5:13 pm #377462Martin
Next thought then…..dial indicator problem? Though I would need to look up a EW12001 to see how the prog dial is on these. Right now on my iPad I don’t have access to the manual so it’s just a passing thought at this stage….
I would need to be in my office for that….. 😀July 1, 2012 at 5:25 pm #377463rocker
Martin, thanks for reply, if you do manage to get any more info on this it would be appreciated. John
July 1, 2012 at 7:10 pm #377464Criscold
I think its doubtful that the timer knob would be at fault if the other programs are lining up and working correctly, I think more likely to be timer and this one comes complete with module mounted on top at about £47 + Vat from Qualtex and EMW do refurbished
July 1, 2012 at 8:28 pm #377465rocker
I feel that probably the fault also, cheers john
