Electrolux EW12001 Spin fault
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Electrolux EW12001 Spin fault
  • #45697
    Latham63
    Machine starts turning,tries to speed up then cuts out.Repeats 5 or 6 times then stops>
    Motor checks out with mega. Generaly machine is in good shape.
    No blocks in pressure system.
    Suspect poss motor fault or programmer??
    #286651
    spimps
    Re: Electrolux EW12001 Spin fault
    Presume this is just before it should spin,it ramps up but doesn’t go into the spin.If the machine is doing it when empty if the motor has no earth fault it’s the timer/pcb out of balance section that isn’t reading the motor current correctly so means a new timer/pcb.
    If you set it to spin it will attempt to ramp up usually 3 or 4 times and then advance through to the end of programme without spinning,is also another pointer.
    #286652
    wizard
    Check the tacho magnet on the end of the motor, had loads of these fall off the end of the shaft. Just refit with a bit of loctite.
    Wizard
