electrolux EW1200i
Viewing 15 posts - 1 through 15 (of 15 total)
  • #49469
    rocker
    can anyone tell me the number on the motor control board, as emw require this, before they can sent one out. thanks John.
    #299990
    Re: electrolux EW1200i
    You could try 1249283126 but as there are six EW1200i models the Pnc number might help. 😉
    #299991
    rocker
    Iadom Pnc 91467401001
    #299992
    😕 ❓ :rolls:
    For some reason there is a big space where the PCB should be on the diagram for that machine. It looks like that one has a hybrid timer/control unit.
    The number I gave does fit most of the others, perhaps one of the chaps who has access to Pro Corner may know better.
    #299993
    rocker
    Iadom, thanks for trying. John
    #299994
    Alanj
    Hi Rocker,
    the timer you require is DST1320558107 or 513316 in EMW catalogue. 😀
    Alan
    #299995
    rocker
    Alanj, need the pcb board that controls motor, not the timer. John
    #299996
    That pnc no. uses a combined timer/module unit called a VS80 – p/no 1320558-12/3.
    rocker
    Cheers Chris, John
    #299998
    Alanj
    Hi Guys,
    I think you’ll find it’s the same timer/module. 😆
    Alan
    #299999
    There are some models of the EW1200i that show the seperate base mounted ‘L’ shaped module..1249283126 and some that have the combined ‘hybrid’ unit.
    That PNC number does not show the base mounted module but the hybrid unit 😕
    #300000
    Alanj
    Hi Jim,
    TDS disc shows this timer/module for this pnc.
    Alan
    #300001
    Thats what I am looking at as well but it would appear that rocker has seen the machine and the module, so either his Pnc number is wrong or the TDS disc is. ❓
    #300002
    Alanj
    Hi Rocker,
    have you been to this machine? Did you see motor module? or has EMW confused you by asking for number off timer/module ❓
    Alan
    #300003
    rocker
    Hi gents, no I never called to see job until today, have traced no spin fault to timer/module, and ordered today from emw, so many thanks for all your help. Thanks again John
