Electrolux EWD1214I leak
Home Forums Public Support Forums Help And Support Washing Machine Help Forum Electrolux EWD1214I leak
  • #62205
    CharlieR
    We moved into a house where the above washer/dryer was already installed (built in).
    Since then we have noticed some damp on wall adjoining kitchen and by looking under the machine I can see that it is leaking onto the concrete floor. Can’t tell if this from connector hoses or not but from the look of it, seems to be from underside of machine itself.
    As it’s built in, I can’t get the machine out so will have to get some help on this but would appreciate any advice or feedback as to next steps.
    Many thanks.
    #349224
    odom
    Re: Electrolux EWD1214I leak
    Assuming you’ve already checked the door seal for rips, the machine needs to come out, it’s the only way to find a leak. Check inlet hose, then tip machine back and you can normally see where it’s leaking from.
    #349225
    CharlieR
    Thanks Chris – it’s def not the seal, but I’ll have to get help with removing the unit as it’s built in.
    Cheers
    Charlie
