electrolux ewd1409
  • #50886
    eng14
    guys this w/d has had new card,before nothing on the dryer side,now wiith new card fan motor comes on but no supply to elements,stats fine,help please,richard, 😕
    #306243
    aqualectric
    Re: electrolux ewd1409
    There is a thermistor for the drier situated on the lower hose from the condenser to the tub. Lean the machine back and look up and it is on the right with orange wires to it.
    …..Or not!! …..as they usually snap off from their plug and cause a spurious ‘no heat’ fault on the drier. Cut back the wires, pull them out of the zip tie that yanked them off (this allows some slack so the drum movement won’t pull on the wires again) and refit with insulated amp tags.
    Hope that helps,
    Steve.
