Electrolux EWF12108W prod no 914900001 00
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Electrolux EWF12108W prod no 914900001 00
  • #69026
    knobs
    Hi All.
    Machine will not show display at all,none of the LEDs light up ,so m/c appears to be dead,but the door lock energises.
    any thoughts.
    had control board off all connectors look ok.
    also bearings have a very slight rumble,have e/lux had a problem with this run of machines ?
    thanks
    #373474
    Re: Electrolux EWF12108W prod no 914900001 00
    knobs wrote:Machine will not show display at all,none of the LEDs light up ,so m/c appears to be dead,but the door lock energises.
    Ribbon cable connection between the 2 boards? Duff display board? Duff Power Board?
    knobs wrote:also bearings have a very slight rumble,have e/lux had a problem with this run of machines ?
    Nope, just normal bearing (possible shaft too) wear. Regular split drum fitted on this machine.
    #373475
    knobs
    No board out all connections ok
    Re checked still the same
