Electrolux EWFI4I08W wont spin
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Electrolux EWFI4I08W wont spin
  • #58833
    Sean Og
    got a call from a lady says she was doing a 60degree wash and it washes but doesn’t spin am thinking speed motor control – then she says she put on an empty 90degree wash and it ran correctly – any ideas please 😥
    #335817
    Re: Electrolux EWFI4I08W wont spin
    OOB. :con:
    #335818
    Sean Og
    I changed the belt start the machine it went through the wash cycle but still wont spin tried a spin cycle machine displays 13 goes through the cycle gets to the part where it about to really spin then it stops at 8 on the display thinks its finished and the display goes back to 13 Help please???
    #335819
    Sean Og
    further info she says she ran a 30min wash empty and it stopped after 8 mins so that kind of rules out OOB is it the PCB??
    #335820
    Do you have the TDS disc?
    Sean Og wrote:further info she says she ran a 30min wash empty and it stopped after 8 mins so that kind of rules out OOB is it the PCB??
    I believe this beast uses a 3 phase induction motor? It could be that the inverter module may need looking at? 😕
    #335822
    Sean Og
    Hi Jim
    Yes I have a TDS disc
    Johnny
    #335823
    Sean Og wrote:Hi Jim
    Johnny
    OK, it saves me sending you tech info. 🙂
    Martins suggestion may be the way to go, not seen this fault myself TBH.
    #335824
    Sean Og
    thanks guys for the info will let you know the result
    Johnny
