Electrolux EWI2001 No spin
  • #63552
    pmb
    Electrolux EWI 2001. 9146701001
    Distributes ok Then starts to ramp up to spin then goes to off on programme.
    Checked pressure chamber and brushes, suspect Programme switch.
    This intergratted machine was a pig to get out, dish had to come out, all on bits of wood hoses to short, tiny kitchen, had to climb on worktop to get to washing machine, thats a moan
    #354114
    Criscold
    Re: Electrolux EWI2001 No spin
    I assume the model should be EW1200i 91467401001.
    If so would also think programme switch no.1320558123
    #354115
    It is a typical fault of the hybrid timer on these. You can get a re-con from EMW and return it if it doesn’t cure fault but I’m pretty sure it will. Alternatively, send the timer to me as I have a theory I’d like to check. (Would take a couple of days and then I’d return it and you could let me know if it worked. 🙂 )
    Mike.
    #354116
    gandh1
    mike has fairies in his pocket, its a form of child abuse i think!
