electrolux ewx14440
  • #57316
    johno1998
    This intergrated washer dryer just over 12 months old powers up pump kicks in and then when it should let the water in the door lock cliks and the machine stops and you can open the door.But if you put it on the dryer cycle it works fine.I have tryed different door interlock same problem 😕
    #330591
    chris211
    Re: electrolux ewx14440
    Have you gone into diagnostics, sounds to me like it could be the dryer element at fault meggar it out and see the results i am sure anything under 40 ohms will be the cause if so just to make sure disconnect dryer element and see if it cures prob poss error code would be ED4
    Chris
    #330592
    johno1998
    cheers chris will try that the machine didnt show any error codes.
    #330593
    chris211
    No it dosnt usually show one you will have to go into diagnostics and see what is listed
    #330594
    johno1998
    Did what you said and disconected sensor probe all works fine now just need to order the parts thank once again for your help 😆
    #330595
    Profyaffle
    electrolux ewx14440
    Same thing’s happened to me today. Machine accepts program, drains, defaults to program setting and door lock flashes. Meggered The heater and it’s at 25Mohm, removed heater from circuit and it works fine until I can get the parts!! Cheers, Chris
    #330596
    chris211
    Glad to have been of some help
