electrolux EWX14440W drains then stops Home › Forums › Trade Technical & Spare Parts Forums › Trade Technical Enquiries › electrolux EWX14440W drains then stops This topic has 3 replies, 3 voices, and was last updated 14 years, 7 months ago by LittleMan. Viewing 4 posts - 1 through 4 (of 4 total) Author Posts August 15, 2011 at 5:34 pm #64515 LittleManParticipant Hi this machine will only dry if you put it on a wash it starts to drain then the led goes to 0000 and the door unlocks can anyone help please. Les August 15, 2011 at 7:32 pm #357277 CriscoldParticipant Re: electrolux EWX14440W drains then stops Check dryer heaters – had one of these doing the same – board had been changed by another engineer and it turned out to be insulation fault on heaters Colin August 16, 2011 at 5:48 pm #357278 LittleManParticipant Re: electrolux EWX14440W drains then stops The dryer is working ok its just when you set a wash or any other program it goes to 0000 drains the stops. Les August 16, 2011 at 6:08 pm #357279 washtronicsParticipant Re: electrolux EWX14440W drains then stops i have had this as well, disconnect the dryer heaters and it should work, usually happens if dryer not used much Author Posts Viewing 4 posts - 1 through 4 (of 4 total) You must be logged in to reply to this topic. Log In Username: Password: Keep me signed in Log In
