Electrolux EWX14450W
  • #93380
    Profyaffle
    Electrolux machine gets 5 minutes into cycle then continues to fill with water constantly. No Fault code registered in memory.
    Thanks guys
    Chris
    #454172
    alster
    Re: Electrolux EWX14450W
    Have you meggered it???
    #454173
    Profyaffle
    Yes mate, got normal readings on both wash and dryer elements. The PCB and analogue pressure switch have been changed.
    #454174
    wilf
    if it fills continually does it completely fill the drum to the top? (pressure circuit fault somewhere) have you checked the drain hose is not too far down the waste pipe and causing siphoning?
    just a thought wilf
    #454175
    smartin
    if you have not already i would check pressure hose for holes, i have had a couple of these where it has rubbed through on the tub.
