Home › Forums › Public Support Forums › Help And Support › Washing Machine Help Forum › Electrolux EWX14450W Filling problem
- This topic has 6 replies, 3 voices, and was last updated 8 years, 5 months ago by
Flatplane.
November 1, 2017 at 3:20 pm #92531
Flatplane
ParticipantHi all, I have a problem with the above.
It takes ages to fill now. The initial fill speed is good then after around 10 seconds or so it drops right off. Water pressure seems to be good as all other appliances work as they should. I’m wondering if this could be the fill valve?
It also pauses it’s self now if it doesn’t fill within the first 15 minutes, I’m not sure if this is an autocut off. I.e. if it doesn’t reach the required fill level in 15 minutes it assumes a fault so pauses its self. I hope that makes sense. Cheers!
November 1, 2017 at 3:44 pm #451521Martin
ParticipantRe: Electrolux EWX14450W Filling problem
It does sound that the valve is faulty. And yes it will time out if not filled within 5 or so minutes.
November 1, 2017 at 3:47 pm #451522Flatplane
Cheers for the help Martin, any other things it’s likely to be, or is the fill valve the most likely culprit??
November 1, 2017 at 5:01 pm #451523Martin
If you are certain there’s no issue with the water pressure to the machine then it has to be the valve at fault. A common enough problem anyway.
November 2, 2017 at 8:54 am #451524Flatplane
I don’t suspect the water pressure. As I say everything else works as normal. And it fills ok for the first 5 seconds or so then drops off to a dribble.
As an aside, is this a Zanussi in a different case?
November 2, 2017 at 9:48 am #451525Martin
Flatplane wrote:As an aside, is this a Zanussi in a different case?
Yes Zanussi are part of the Electrolux group of companies so there are badges versions of the same product. Including AEG, Blomberg, Electra, Ikea and so on.
November 2, 2017 at 5:17 pm #451526steven cave
had same problem on a indesit one and that was the water inlet valve one off them had broken and would let one side off the draw fill up and other side had a slight dribble change the valve now works perfect
