Electrolux F/Freezer Fridge Not Cooling
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Electrolux F/Freezer Fridge Not Cooling
  • #57876
    a1al
    Hi everyone
    The freezer works fine but the temp in the fridge is to hot.
    Advised customer to switch off for 2 days when it was switched back on freezer seems fine, temperature in fridge drops down and then in less than 20mins starts to get warm.
    Mod ENB 35405 S
    Prod 925034017-00
    S/n 7080001
    a1al
    #332533
    Seamy
    Re: Electrolux F/Freezer Fridge Not Cooling
    Couple of things to check, that motorized flap is opening o.k & theres no blockage in duct from freezer to fridge, that fan is turning o.k, (i’ve had a few that turned o.k but were not as fast as they should be). Check door sw’ in freezer is working o.k also.
    #332534
    TeeMyob
    Can be fan motor or module fault. Fans sieze, modules skip defrost.
    Also beware of low refrigerant (leaks). Or, compressor issues . This can fool you into the aforementioned.
    Heaters and sensors rarely fail.
    TM
