Electrolux ff
  • #98872
    Alex Craig
    Hello to Everybody,
    I hVe sn integrated FF model No ENN28600 and 2 days ago the fridge light bulb blew.Replaced bulb ok but I’ve noted that the light doesn’t go out when I shut the door….or depress the switch???
    How do I access the switch, anyone got any ideas? Thanks for any advice
    Best wishes
    Alex
    #474109
    would need the pnc number but the one i looked up showed lamp is controlled by the board
    Alex Craig
    Hi David,
    THank you so much for replying.I was going to add the PNC No ( 925 – 771 – 737 – 09 on my original message but forgot to add it.
    What happens is, if I insert a bulb in the fridge light the bulb stays on.I could prove this by putting my phone inside the fridge on video and shut the door!
    The light flickers very slightly when you depress the door switch but doesn’t go out.
    I also noticed the small green pilot light goes off when you activate the door switch….is that normal?
    if its a board is this something I could purchase or would I have to go through a repair centre?
    AGAIN many thanks for your assistance with this
    Rgds
    Alex
    #474111
    you need to do one of 2 things and probably both in the end
    remove the door switch and check it electrically
    remove the pcb and look for track or component damage
    Alex Craig
    Thank you for the suggestion.The problem I have is knowing how to remove the switch and PCB I mean do I unclipped the plastic round about it or are there screws I have to remove.It all looks very tighly constructed and If I go about it the wrong way then I could break something
    #474113
    found this on switch
