Electrolux FF ENN26800
  • #67586
    DDDave
    I dont normaly fix FFs but this is a friends one so I am looking for advice please. The freezer works but the fridge is warm.
    Any ideas of what I should check please.
    Thank you
    scientist
    Re: Electrolux FF ENN26800
    Have you checked the evaporator at the top of the freezer?? If this is choked up with white ice then this will prevent the air circulating up to the fridge compartment. This can be caused by 1. faulty heater 2. Faulty sensor at the rear of the evaporator. The evaporator drops down with a bit of manouvering. Hope this helps.
    #367888
    DDDave
    Thanks Scientist. I havent checked that as I didnt have a clue where to start.
    Cheers
