Home › Forums › Public Support Forums › Help And Support › Fridge And Freezer Forum › Electrolux fridge ER6641T warm
- This topic has 7 replies, 3 voices, and was last updated 14 years ago by
sherlock9.
March 10, 2012 at 10:48 pm #68368
sherlock9
ParticipantHave an Electrolux Fridge model ER6641T which is warm and the light still working the thermostat appears to work have switched it off light in the fridge goes out. With the power on there is 240 volts at the compressor relay but the compreeor does not run. Assume that the relay is faulty but could the problem be the gas filled cappilary on the thermostat.
March 11, 2012 at 9:32 am #370770Dales-Electronic
ModeratorRe: Electrolux fridge ER6641T warm
If you have power to the relay then either the relay/overload assembly is faulty or you have a duff compressor – if on switch on you get a hum followed by a click then its the compressor.
March 11, 2012 at 5:29 pm #370771sherlock9
ParticipantRe: Electrolux fridge ER6641T warm
Thankyou for your quick reply to my query. I will try the relay/Overload to rectify this fault because have checked the resistence of the compressor windings and the resistance between the bottom 2 pins is 72 ohms and about 38 ohms between the top pin and each of the bottom pins.
Is there a site you would recommend to get the spare relay/overload from because most of the site that I have looked at do not seem to have it availableThanking you again for your assistance with this matter.
March 11, 2012 at 6:29 pm #370772captaincaveman1
you may have power to the compressor but have you a neutral? I would say its far more likely the thermostat
March 12, 2012 at 1:05 am #370773sherlock9
I have a neutral at the relay I tested the voltage between the neutral and the live conductor.
March 12, 2012 at 7:25 am #370774Dales-Electronic
You may struggle to get the relay as generally they are supplied with the compressor not as a seperate item. If you post up the details on the compressor label we should be able to match it up for you.
March 12, 2012 at 5:16 pm #370775sherlock9
The compressor details are
VOE
GVY35AA
R134a gasMarch 14, 2012 at 11:58 pm #370776sherlock9
Have been able to get the fridge working by installing a universal small compressor starting relay/overload.
Thankyou both for all your help in resolving this fault
