Re: Electrolux fridge freezer 0 degree sensor damaged
Sensor should read between 4200ohms (15c) – 3500ohms (20c) at room temp’. If its faulty most of them are repairable but its a rewire job fitting kit in place of original.
Most common fault on these are the fan not running which causes no transfer of cold air up to fridge from freezer section. Many of them the fan can only be replaced by replacing the evaporator battery which entails refrigeration regassing etc.
Make sure freezer door is closed, fan won’t run with door open 😉
