Home › Forums › Public Support Forums › Help And Support › Fridge And Freezer Forum › Electrolux fridge/freezer problem…
- This topic has 5 replies, 3 voices, and was last updated 20 years ago by
gravygravy.
April 14, 2006 at 9:26 pm #17152
gravygravy
ParticipantModel ER7626B
Type B258870
Prod. ID 925887601
Serial No. 13500073
Refrigerant R134aWe noticed on Thusday pm that the food in the freezer was starting to defrost and the fridge too warm. Turning the control knob to max. for an hour made no difference. Found this forum and read the posts and decided to switch off and leave the doors open overnight. Switched it on again at 16.00 today. The compressor is running, the fan in the freezer is running and control knob on 6. Ater 6 hours the fridge temp is 14C and the freezer temp is 6.3C.
The fridge/freezer is 3years 2 months old with no previous problems.
Can anyone help with a solution or suggest what may be faulty?April 14, 2006 at 9:39 pm #173152admin
KeymasterRe: Electrolux fridge/freezer problem…
It seems like you may have a restriction in the refrigeration system which will require an engineer as its not home/diy fix.
With R134A it is a very common problem.
bryan
April 14, 2006 at 9:48 pm #173153gravygravy
ParticipantRe: Electrolux fridge/freezer problem…
Bryan
Thank you for taking the time to reply.
An engineer it is then.
Takeaways till tuesday woohoo!April 15, 2006 at 5:58 pm #173154gravygravy
As this fridge/ freezer is out of warranty I decided this morning to switch off and remove the back panel inside the freezer. The top of the evaporator had a thick coating of ice the rest of it was not iced at all.
The condensor on the back of the fridge/freezer is cool except where the pipe exits the compressor which is very hot as is the compressor. Is this indicative of a restriction?
Is this likely to be an economic repair out of warranty?April 15, 2006 at 10:30 pm #173155Dave_Conway
That would confirm Bryan’s thoughts in that case 😉
April 19, 2006 at 3:06 am #173156gravygravy
Spoke to a local engineer Tuesday (by phone). After hearing the symptoms and asking further questions he confirmed your thoughts that it was a restriction or refrigerant loss.
After discussing options and costs involved to repair have decided to dump it and go buy a new one.
Thank you all for your help. -
