Electrolux fridge not cold
Home Forums Public Support Forums Help And Support Fridge And Freezer Forum Electrolux fridge not cold
  • #49675
    nobodyspecial
    I got a electrolux fridge model ER6641T Type TT 160 C. The problem is it’s not cold inside the fridge so i have checked to see if anyone has turned the temperature dial down but it’s still in the same place so i was wondering if anyone knows what could be wrong with it.
    #300656
    spimps
    Re: Electrolux fridge not cold
    Can y ou hear the compressor running ?if you can it’s a system fault,likely refrigerant loss.
    Is it silent ? if it is, possibly thermostat failed which would be a cheaper and viable repair.
    Unplug always.
    #300657
    nobodyspecial
    Thanks for your reply. No you cannot hear any sound from the fridge.
    #300658
    spimps
    OK,if the motor(compressor) is cold to the touch then it’s likely the thermostat.
    You will need a meter/avo to establish if the thermostat is open circuit/failed.
    #300659
    nobodyspecial
    I went to a repair shop by me and they said if it’s the thermostat it will cost £55 for the part and to fit it. The compressor is cold so if i buy a thermostat from here is it a easy job to do.
    #300660
    spimps
    Yes ,if you can hold a screwdriver 🙂
    Couple of screws to release the housing then you will see the thermostat.
    Look at the new one and note the terminal numbers ,change the connectors by the numbers they will be on the old one too.
    UNPLUG FIRST !!
    #300661
    nobodyspecial
    Bought a thermostat from here so just waiting for it to come now so until then no cold beers in the fridge so i will have to blame my girlfriend for not cleaning the fridge out and thats what caused the thermostat to go and now she will have to let me go to the pub.
    #300662
    nobodyspecial
    Thank you for you help spimps it was the thermostat after all.
