ELECTROLUX FRIG/FREEZER
Home Forums Public Support Forums Help And Support Fridge And Freezer Forum ELECTROLUX FRIG/FREEZER
  • #88079
    Jeff613
    I have an old Electrolux frig/freezer TR71/55.
    It is about 40 years old and has given (and continues to give) excellent service!
    However, one fault has developed.
    When defrosting (this has to be done manually – it is not an automatic defrost machine) the water does not drain away down what seems to be a small ‘plug’ hole in the middle of the bottom of the freezer. The water is supposed to enter this drain hole , go down a plastic hose and exit at the end of the hose.
    Something must be clogging up this plug runaway. It looks as though it can somehow be unscrewed but I don’t want to force anything!
    Are you able to give some advice?
    #436951
    Seamy
    Re: ELECTROLUX FRIG/FREEZER
    I’d use a pipe cleaner or cable tie to poke into hole in fridge to see if you can dislodge the blockage.
    I myself have used a long piece of pipe same size as hole & blown through it to shift blockage, but be careful as there’s likely to be germs in it & , Don’t INHALE ❗
